i ended up going down the mercedes route with my golf, thier batteries are made to ridiculously stringent specs as the can system in them is so sensitive, like doc i fitted the rigid battery box, looks so much better and not expensive from vw either i think i was circa £40 for the 3 parts
Doc wrote:Hi Alex,
I have a 096 battery in my Caddy and it fits the tray but not the soft cover.
I have fitted the ridgid battery box found on the earlier Caddys and golfs.
I plan to change my battery to the 096 as you guys have done so, as I believe it's on the way out, I've also had a new genuine alternator fitted due to bearing noises..
Any chance you could give me part numbers you used for the box in your caddy?? 3 parts so you say
Also just wanna make sure it will fit in my 1.6 2011 facelift 1.6 caddy 105bhp??
Have a look at Tayna batteries website if you're buying. Excellent service from them and quality batteries, not the usual crap from GSF or ECP. I just recently got a 096 Enduroline 78Ah after constantly suffering with battery drain during winter, that despite previously having a new battery from GSF. I've not suffered with any issues since fitting the new one. £80 I think I paid, well worth it.
It is a bigger sized battery si I'm interested if the battery boxes fit the larger size?
phil wrote: ↑Sat Mar 25, 2017 8:53 pm
Dont suppose you could help me with the part number for the rigid battery box?
Thank you
Very much appreciated
Think I found the link online aswell: https://www.ebay.co.uk/itm/VW-Battery-B ... ctupt=true
This above link is NOT GENUINE but a good aftermarket so the seller say.
Will check with TPS though now and get this sorted
Thank you!!
Reason:removed quote of previous post
