Upgrade steering wheel - DSG Paddles
petrev
Engine size/power: 1.4TSI
Post by petrev »
I have just got a Polo multifunction wheel with DSG paddles.
According to reading stuff hereabouts it should be a direct swap - But - It has different Cruise Control buttons on the left.
When people write that you should change the buttons, I take it that the different buttons actually function differently, not that they just have the correct legend on the caps !
Can I just use the buttons as-is, missing the Mode Button and with a redundant ACC-Distance button?
Advice gratefully received,
Pete
Giddy
Re: Upgrade steering wheel - DSG Paddles
Post by Giddy »
It's hard to guess what's you current setup, etc., but have a good read here, it may answer your questions.
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
petrev
Post by petrev »
Thanks.
Plenty of good info to digest.
I should have said
Caddy Mk4 2018
DSG
Std. cruise control
Caddy now
Polo (ACC)
Pete
petrev
Post by petrev »
Thanks again.
That is perfect info, just where you pointed me.
Will have to code out speed limiter apparently and then all should be good ... Fingers crossed.
petrev
Post by petrev »
UPDATE :
If you don't have ACC then an ACC wheel is not much use - Lots of work / Money to change it to be correct (new buttons, a module, or soldering and modifying old buttons !!! required)
Ah well - worth a punt .
sipep
Engine size/power: 2.0 CR TDI (138bhp)
Post by sipep »
Any updates on this,
I have MFSW with ACC / Mode button looking to get DSG paddles.
