Dsg steering wheel
- Caddy Dan123
- Twin Turbo poster
Dsg steering wheel
Hi folks so i have a mk4 1.4tsi and i was wondering if its possible to h e the paddle shift working if i fitted a golf r steering wheel only problem is not sure if theres a 7 speed as my golf r is only 6 but my van is 7.
Sent from my SM-G998B using Tapatalk
DW2207
- Engine size/power: 1.9 TDI (104bhp)
Re: Dsg steering wheel
Hi mate, this modification is achievable as I have this setup alas on my 2012 1.6tdi 7 speed dsg. I don't think the number of gear ratios is a problem tbh.
I believe all you will need is the correct steering wheel and if you have access to vcds or know someone your all good as your van supports the latest lin bus system for this retro fit.
Sent from my SM-G981B using Tapatalk
petrev
- Engine size/power: 1.4TSI
My experience doing this.
Swapped to a DSG Std. Wheel on my Mk4 TSI 1.4 no probs. No coding required for a button set with Mode button.
Same for GTI wheel, R-Type.
Only need to code if it hasn't got the Mode button.
Simple code change to switch off Limiter mode option.
POLO 6C GTI Buttons are illuminated Red if you need to be co-ordinated !
Note: ACC GTI does not work as far as I can tell.
Imprintx
- 100BHP+
- Engine size/power: 2.0 TDI (140bhp)
I got a mk8 touch button mfsw with paddles and all functions working
- Caddy Dan123
- Twin Turbo poster
@petrev
Awesome mate so how does it work as my golf r is only a 6 speed as i was jist going to buy another golf r wheel but didnt know whats what with having that extra gear buddy
Reason: Removed quote
petrev
Using a Spacewalker Module ?
Or some other way ??
petrev
DSG Buttons are just Up/DownCaddy Dan123 wrote: ↑Tue May 10, 2022 1:55 pm @petrev
Keeps going 'til it runs out of gears ....
May need to code Module 17
Byte 1
Bit 4 = Tiptronic
Mine is not coded and works
- Caddy Dan123
- Twin Turbo poster
Ahhh so doesnt matter about the gears then paddles will run upto 7 anyway then sweet do you know if its same way of removing steering wheel as mk3 and do i require anything else
petrev
Getting the Airbag/Horn off is the tricky bit
May be slightly different to Mk3.
2 holes on the back. One wire moves to release 2 clips at once and is a bit of a pain !
There is a How 2 (pretty sure !)
Anything else required depends on what you have already.
MFSW already ? Just adding one with Paddles ?
Upgrading other stuff, then ????
May also need a tiny bit of coding, but I can't remember
Imprintx
- 100BHP+
@petrev
Yes using a spacewalker module mate
petrev
- Ripley55
Custom Polo R wheel, just coding
Chestnut Brown Caddy MK4 Maxi Life 2.0Tdi 150bhp , 18” Matt Bronze OZ Ultraleggera’s 8Jx18 ET45 on Bridgestone 225/40/18’s
sipep
- Engine size/power: 2.0 CR TDI (138bhp)
Can I get a polo R steering wheel with acc that works?
petrev
R Steering Wheels with ACC need a module to work !
Spacewalker or other.
