12K PLA retrofit
strizek
12K PLA retrofit
Hello everyone, I have a Caddy maxi IV 2016 and I would like to add parking sensors with parking assistant. That requires 12 sensors, which is not a problem, but when I looked in the rear bumper, there are marked holes for only 4 sensors, not for the side ones. Does anyone have 12K sensors on their Caddy? I would need to measure approximately where the side sensors should be, or I would welcome a photo of the outside and, if anyone has one, the inside of the bumpers. Thank you
miko89
Re: 12K PLA retrofit
In caddy 2016+ you have 2 options of park assist one is with 4 sensors on the back ist regular, other is with self parking and have 6 on front and 6 on the back
c00LhaNd
@miko89
From factory thats right.
But if anyone want to retrofit PDC it is possible to upgrade from only rear PDC with 4 sensors (with and without OPS) to rear and front PDC with 8 sensors (with and without OPS).
To upgrade PLA (park lane assistant with 4 sensors on the side) you have to upgrade the abs block with ecu and the rear abs sensors, too.
But that wasn't his question. ...
@ strizek
Have you got a template for the holes for the pla side sensors?
I want to upgrade from rear PDC to front and rear PDC + PLA, too.
@ strizek
