Bi-Xenon and DRLs
mini.rich
Bi-Xenon and DRLs
Post by mini.rich »
Hi guys,
Looking for a bit of info/advice/help....
My van is a 2020 Highline, I fitted Xenons from a near identical Maxi(same spec apart from it had parking sensors and no heated seats, even same colour!) at the weekend, I copied the necessary bits from the long coding but I still have one issue, I think..
Are the DRL's supposed to be on with the dipped/main beam? Bit 7 is selected on byte 24 for DRLs as position lamps
Coding was taken from the doner vehicle, however I had to change byte 18 as it was 00, changed to C2 as per some of the threads I read on here and this sorted out all the issues I was having apart from the DRLs with dipped/main. Everything else seems to work as expected.
Coding is currently - 411A0A3E8037E16A08880082944009EC03DDC20842228620E48487000045
Any help/thoughts would be appreciated Thanks! :)
2020 Blackberry Purple Highline, 150bhp, DSG.
gazza31112
Re: Bi-Xenon and DRLs
Post by gazza31112 »
491A0A3E8025E16A08880082904008 6C0385C208420080A0648487000045
This recently worked for another forum member
Sent from my Pixel 8 Pro using Tapatalk
mini.rich
Post by mini.rich »
gazza31112 wrote: Tue Dec 09, 2025 3:43 pm 491A0A3E8025E16A08880082904008 6C0385C208420080A0648487000045
Thanks, I’ll give it a try in the daylight tomorrow 👍
mini.rich
Post by mini.rich »
So there is a conclusion to this in case anyone else has the same issue. I found byte 21 was set to 22 on my van, it wouldn't change to 00 by changing the bits so typed it manually and it worked. Hope this can help someone else in the future! Thanks again @gazza31112
