Caddy Maxi - daily and camper build
Sebhell
Re: Caddy Maxi - daily and camper build
Stumbled upon your thread looking at doing similar work with my newly acquired Caddy Maxi 2.0 TDI 4M.
Trying to navigate all the different opinions on sound treatment and insulation is a nightmare when you're a little bit too used to falling down the rabbit hole of research before getting started!
Feels a little bit better following a fellow Swede knowing you might encounter similar environments although I live a fair few hours up north between Åre and Östersund.
A question regarding the cargo flooring. How do you fasten the flooring on top of the sound and insulation treatment? Glue I'd assume is out of the picture as it would only adhere to the insulation foam. Did you screw or bolt it down on top of the treatment?
Love your build and attention to detail, looking forward to the continuation of the thread!
Sparktan
Was this a straight swap from the rcd310 , everything works as with the old unit apart from bluetooth music control which endeed will be a bonus ! Thank you in advance
- Poffe
Cool mate! Sorry for late reply. Been of from the forum for a while. Same engine as me then. I also bought mine for transporting bikes (doing some triathlons), motorbikes and so on. And I hope the camper conversion vill still allow that.
Caddy Maxi 1.6 TDI -2014. First time VW/Caddy owner, already deep in the rabbit hole
- Poffe
Yeah, it is cool to see all the different solutions and styles to modify these Caddys in. Once in a while you see something that is too good to not copymemzieh250 wrote: ↑Fri May 02, 2025 7:07 am great inspiration!
always good to see how people put things together in their own way, its like a signature.
- Poffe
Nice to see a fellow Swede here as well! Yeah, I think we almost get a totally different climate than most of the other users here on this forum. Although, I'm guessing that you get even colder temperatures than I do.Sebhell wrote: ↑Mon Jun 02, 2025 12:17 pm Stumbled upon your thread looking at doing similar work with my newly acquired Caddy Maxi 2.0 TDI 4M.
The floring actually isnt glued, it is just placed on top of the insulation. It doesnt seem to move anyway. It is cut quite tight to the sides and front and back.
Thank you buddy! Your van has the spec i wish mine had. 1,6 TDI with the DQ200 DSG gearbox I have on mine. Probably the worst combo out there.
How are your build comming along?
- Poffe
Got hold of some Touran door cards a while back. Pulled them a part, reupholstered the center sections and armrests in black alcantara to match the ceiling and pillars. Nice enough upgrade
Sent from my Nokia 3310
- Poffe
Made an LH inner panel in glass fiber, plan is to upholster it in alcantara as well. If it al works out, I’ll continue on with the RH.
- Poffe
Got my hands on a set of MK4 Rear lights. Started searching what was needed repinning wise and in the end I came up with this:
(Mind you, i have a LHD van)
At first, all the functions worked, but there were still some fields that didn’t work. But it turned out to be broken bulbs, not the pinning or coding.
Now, how do I get rid of the broken bulb light on the dashboard? From DTVs video I thought the coding would be an easy fix. But in regular fashion when I’m doing something I have a bit of bad luck. Seems like Caddy’s 2010-2015 have a different BCM (09 Central Electric) than pre facelift. Just Ross tech VCDS doesn’t seem to cut it.
Mister_ShWa
loving your project, lots of interesting ideas
- Poffe
Finally the Mk4 lights are properly coded in. A bit of a struggle as always. Turned out that mk3 post facelift (2010-2015) caddy’s have a little more special BCM/Central Electric control module than both pre facelifts and Mk4s.
VCDS didn’t cut it! Had to order Vag Can Pro and search in to the deep web to find VAGHelper in order to be able to properly code it in. Found a helpful video on “How to” on YouTube.
https://youtu.be/C4n2rsFfTxk?si=FWee-FPyd0Tl0BM8
It contained instructions for both pre facelift and post facelift. There is only a slight difference between LHD and RHD in the coding process. I think you will figure it out if you decide to do it.
Bad picture, but still some proof:
Well done
Looking good
Scary stuff, messing about with the binary code !!!
Looking good
- Poffe
Thank you buddy!
Yeah, rewriting anything in the BCM and especially anything to do with the lighting settings came with a fair amount of warnings attached to it. So, I’m very pleased that my messing around worked out in the end.
- Poffe
Spring is finally here in Sweden!
Summer tires were worn and I had to make a call between just replacing the tires on the current rims (VW Passat OEM with clear coat release) or a complete new set.
Found a new set of aftermarket rims and tires for roughly half of. Goodyear Eagle F1 Asymmetric tires and black Carmani rims, 225/45 R18.
Not sure about them yet. Maybe I just don’t like black wheels, or it might be the color and the style. I guess I’ll give it a week or so.
- Poffe
Moulded wheel arc panels in polyester resin and fibreglass. Then reupholstered them in the same Alcantara fabric as every other panel. It has never been so close to be “finished” before.
But, starting to think that I might sell it. The 1,6 TDI hasn’t been that reliable as one could hope for. And going for long trips in a car that might break down in the worst possible situations isn’t fun.
- Poffe
Last pics of the Caddy before I sold it:
