Page 3 of 3
Re: Bcm ‘s
Posted: Sat Jan 11, 2020 6:35 pm
by peely
spychu14 wrote: Sat Jan 11, 2020 1:34 pm You have to use some special tools to read 24c64 eeprom from dashboard by obd or remove dashboard and read eeprom by programmer.
Then i can help with needle sweep :)
I obviously know you can code anything Doc but is this in your can do list if so we will make a time and date pal
Re: Bcm ‘s
Posted: Sat Jan 11, 2020 6:56 pm
by Doc
Yep, I've got a few tools for instrument cluster coding. Drop me a message, we can arrange a date and time.
Re: Bcm ‘s
Posted: Sat Jan 11, 2020 11:21 pm
by r1lea
Doc wrote:Ain't nothing Rossi about me, apart from feeling like I'm 46.
And looking it ImageImageImage
Re: Bcm ‘s
Posted: Mon Apr 13, 2026 4:51 am
by Rhodesian75
Anoneuamus.
Tried following the link to your build thread as suggested as Im looking at a possible BCM swap, but says link "Does not exist"?
My build thread
viewtopic.php?f=13&t=36851
Cheers.
anoneamus wrote: Sun Jan 05, 2020 7:58 am Unless your BCM is 085, there is zero gain from upgrading it (eg. 086 to 087). In any case, it's fairly non-trivial, but procedure goes:
- Save coding from current BCM
- Install new BCM
- Copy coding from previous BCM
- Pair remote key fobs
- Take BCM out of 'factory' mode
The needle sweep is an adaptation of the instrument cluster, has nothing to do with BCM.
