Caddy rear seats
Pics from around the web
stevesussex11
Engine size/power: 1.8 20V Turbo
Caddy rear seats
Post by stevesussex11 »
Hi
Just joined the group
Im getting a caddy or caddy maxi in the next 2 weeks ex britisg gas 1 from the auction
And wanted to get seats in the back
Anyone help with people that can do it im in brighton area
Many thanks
GYCADDY
Re: Caddy rear seats
Post by GYCADDY »
Hi,
I had rear fiat Doblo seats fitted for about £1200 at fast fit nationwide in West Bromwich.
they did a good job, takes a full day but worth the drive. I would show you a pic but new to the forum and not sure how to add a pic.
Limbo118118
Post by Limbo118118 »
Seen a few setups on ebay fella
Insta : Limbo118118
menz21
Post by menz21 »
I purchased a set of caddy life seats off eBay from Germany.
Got them new from a company that did rear access modifications.
I purchased the sub frame part separately but the hardest bit was sorting out the seat belts.
c@ddyme
Post by c@ddyme »
Hi is it quite easy to fit these then? Does the fittings bolt in looking at this option as im thinking i may be able to fit myself... how did yours go???
chunk22393
Post by chunk22393 »
Think there’s about more to just bolting them in bud, from what I’ve seen you have to remove a welded panel from the floor and weld in another section with the seat mounts in place!
Jono1
Post by Jono1 »
I’ve put touran rears in mine. Easily removable if you still need the van space.
There’s quite a few threads on them on here 👍
lscott141
Post by lscott141 »
@c@ddyme
Look up a boy called Dan Chambers on Youtube. He has a Caddy restoration series and he shows how to fit rear seats. Defo not a bolt on job.
Reason: removed unnecessary quote
ProJex
Post by ProJex »
I got a 3rd row bench seat from a maxi life thinking they would bolt straight in to a standard swb. They don’t! But not impossible and looks easier than fitting the 2nd row Touran option. Either need to drill 4 holes through the floor avoiding fuel tank etc or mount to a bit of 40mm unistrutt and bolt the unistrutt to the floor in a convenient place. I’m going to have a look this weekend and see how it goes.
M13CYY
Post by M13CYY »
Depending on where you are based, I used Caddy Solutions last week to get my rear seats fitted and also the rear insulated and carpet lined. I would very much recommend them and they are very competitive on price I found.
