Page 1 of 1
Rear fog light issue
Posted: Tue Aug 06, 2019 7:30 pm
by alfieargyle
I'm after a bit of help and guidance please. I've got a warning message on the dash 'check rear left foglight'. I've checked and the lamp is fine. Before I start delving deeper does anyone know what the issue might be? Thanks in advance 👍
Re: Rear fog light issue
Posted: Tue Aug 06, 2019 7:35 pm
by Doc
You say the lamp is fine, does it light up?
Yours is a LHD caddy? Rear fog is only on the drivers side so it must be.
Have you checked the plug and socket for corrosion?
Posted: Tue Aug 06, 2019 8:23 pm
by alfieargyle
Hi Doc, thanks for the reply.
Mine is a 2015 RHD! I removed the rear left cluster and all the lamps were fine. Filaments all good and did a continuity check ok. I assumed there must be fog lights either side. I checked the fog lights and the fronts come on ok but nothing on the rear (left or right)!!
Posted: Tue Aug 06, 2019 8:29 pm
by Doc
That is weird, maybe there is a mistake in the programming of the error message as the rear fog is only on the drivers side. Maybe someone at VW has missed this and it has only been set for a LHD vehicle.
Is yours a Caddy4, 2015 was the changeover year?
Posted: Tue Aug 06, 2019 8:51 pm
by alfieargyle
It's one of the last black edition models so think that's before the caddy4?
Only had it a week and the 'rear fog light warning' has only came on in the last two days.
Could it be connected with the rear compartment light as I've disconnected that and dropped the roof lining to soundproof the back?
Posted: Tue Aug 06, 2019 9:38 pm
by Doc
Nah, it won't be related to disconnecting the interior light.
Have a look at the right side tail light, that's where your rear fog should be.
Posted: Wed Aug 07, 2019 7:53 am
by alfieargyle
Thanks Doc, I'll look this morning and let you know👍
Posted: Thu Aug 08, 2019 4:36 am
by alfieargyle
Thanks Doc, all sorted. It was the fog light that had blown, but as you pointed out it is on the right hand side and not the left!! Thanks for the help.
Posted: Tue Dec 13, 2022 6:34 pm
by Lambrettacraig
Hi just had the same on mine. Dashboard warning light and the following warning;
Check fog light left side.
MOT tester said it wasn’t the bulb, could be a wiring issue. No front fogs fitted, only rear. When pulled out, the fog light on warning comes up, but the actual fog light isn’t on.
Has the mechanic made a schoolboy error and checked the left side and not the right side?
Thanks in advance
Posted: Tue Dec 13, 2022 6:53 pm
by Doc
Most likely if the instrument cluster is saying the left side is blown then he will check the left, even if there is no rear fog there.
Posted: Tue Dec 13, 2022 7:17 pm
by Lambrettacraig
Will check right side bulb in the morning.
Posted: Tue Jan 10, 2023 1:59 pm
by Lambrettacraig
Van went back in today. Just had a call to say the garage thinks the BCM is at fault. He’s gonna run an independent relay to the rear fog, so it still works off the switch.
He said the dash light would probably stay on.
Can the relays on the BCM be changed individually? If so is there a specific one for the rear fog light? It’s beginning to get a bit of annoying problem now.
Thanks in advance
Craig
Posted: Tue Jul 22, 2025 2:55 pm
by Andypee93
Picking up an old thread I know..
I've got a similar issue at moment, I've got a dash warning light saying check rear left fog light (pretty sure it's only on the drivers side)? Also noticed the interior lights had stopped working.
Checked bulbs, all good, checked fuses and no.22 10amp fuse had blown. Replaced that but keeps blowing? All wiring looks good can't see any breaks.
Any help much appreciated
Caddy maxi 2014
Tia
Posted: Tue Aug 05, 2025 10:37 pm
by STP
Shorted bulb maybe? Take the bulb out, check the terminals. See if the fuse holds with the bulb out. Some bulbs on the Caddy are twin filament brake and tail bulbs doing one job with varied brightness, so make sure you haven't fitted a single filament bulb in a position that requires a twin filament one, as it shorts both terminals together. If there's two brass strips at the bottom of the holder, it needs a twin filament bulb.
