Caddy MK3 Canbus Gateway RCD330
Samoop
Post by Samoop »
Hello,
I have a 2008 Caddy MK3, I'm looking to fit my RCD330 unit that was in my Mk5 Golf, the golf was luckily plug and play, powering on/off as expected, and working with steering wheel controls.
Unfortunately, when installing it in the caddy, it's clearly not functioning properly, it will launch instantly as if not powering off properly, and will not connect to Bluetooth as will state "switch ignition on" I sense this is the very common canbus issue not telling the unit the correct information, and subsequently lead to power drain, so left it unplugged.
My question is, what Canbus module would I need to get to then configure to work with the caddy.
My current one is
Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 061008F2001315
Coding: 89801F060002027401
I've been looking online and seen people mention 7N0 907 530AJ which can be set up for use in the caddy, but thought I'd get some advice from people on here first!
Thanks
2008 MK3 Caddy, Off Road Grey, 1.9TDI ASZ, 6 Speed manual
Faultybydesign
Re: Caddy MK3 Canbus Gateway RCD330
Post by Faultybydesign »
Hi, did you ever manage to figure this out? Cheers.
