Hi I'm new to this so bare with.
I've got a 2007 caddy with manual windows which I'm try to convert to electric, I've bought regulators and looms but the block at the door pillar end are different to the originals.
Can the electric window loom have the original plug pinned onto it or do I need to find earlier loom from somewhere?
Hope this makes sense.
Electric window conversion
Ady9869
Azzi
Re: Electric window conversion
Just about to do the same on my Caddy, apparently you have to use the Caddy Loom, then manually pick out the wiring from the Touran loom from the window switch to the control box. that saves you having to repin the big socket on the door pillar.
Also theres a missing power feed to the door post to be added and again from the post to the motor.
Someone correct me if I'm wrong.
